So I've been under my 2013 3500 Laramie Longhorn (new to me) (54,000 mi)...
I'm still having issues with fueling... can't see any issues, but the tank will not accept fuel unless I hold the nozzle, and throttle the nozzle... it won't accept the fuel at the slowest setting...
I've tried nozzles without the splash shield and have tried several suggestions by others on this site... but can't seem to get the right angle... maybe try and twist my tongue differently.. who knows...
My tank to filler has 3 lines... all metal... fill line, vent line and an unknown line about 7/16 to 1/2" diameter going to a small can that is attached to the filler line (pipe) with a plastic wire tie... the DEF lines are easy to get to... but I see an issue to remove the tank lines at the tank and pull down the complete fill assembly.... Could this last metal line be a vent line and the can on the end of the line a filter??? maybe 1 1/2" diameter and 2 1/2" long...
Can someone share what the 3rd smaller line is coming from the tank to the filler assembly.... I can't see how to open the vent line unless I use a saw... thought I might get a tubing cutter in there and cut out a section and install a tee.... there's lots of room to run a vent hose up in a loop in the space along side the bed...
