Engine/Transmission (1998.5 - 2002) Very Happy with LUK clutch
2nd Gen Non-Engine/Transmission change to posi?
Engine/Transmission (1994 - 1998) Pacbrake throttle switch bypass?
Received the new clutch,and got the old one out... . That crossmember design SUCKS !! #@$%! Flywheel was ground 14 thousandths. Does anyone have the torque specs for the flywheel,and pressure plate?It's a 2002 H. O. . Thanks.
New clutch is in..... Now there's a problem getting it into gear. :rolleyes: It seems as if the clutch slave isn't disengaging the clutch fully. The pedal is a lot softer than the stock unit. I've done clutch installs before,and never had a problem like this before... ... Any ideas?
Possibly someone pushed the clutch pedal down when in service getting air in the unit. Have you tried pumping the pedal?
Yes,I've tried pumping the pedal,and even plowed a few driveways with it since i installed it. I've only put approx 150 miles on it so far. It does seem to be getting a little better with use. Maybe the hydraulics have to "re-set" themselves. :confused: Other than this problem the clutch works GREAT!
