This is my first post, please advise if I have done something wrong.
My truck: 2001 2500 auto trans. 4X4, LB Ext. Cab. I have the “fog” lights option.
I just installed a Banks Power Pack unit on my truck. I ordered two extra gages, along with the two that came with the package.
The engine oil temp and auto trans temp gage. In wiring the gauge lights,(4 total), I removed the headlamp switch and located the wire that controls the dimmer. I wanted the gauge lights to be on the same dimmer as the instrument panel lights.
Here is my problem:
When I turn on the headlight switch, after about 20 plus or so minutes, the panel right around the dimmer switch gets EXTREAMLY HOT!
How can I reduce the heat problem at the dimmer/rheostat/pot? I want to keep the Banks gauge lights on the same dimmer/rheostat/pot as the rest of the instrument lights.
I called Banks with this problem and they said it could be a bad ground.
The area where I put the ground was scraped clean before attaching the ground lug. What can I do to reduce the extreame heat around the dimmer wheel?
Here is my problem:
