vibes at 70
Wiper Motor
Longer control arms ?
sag2 said:
TTubb
I have fixed quite a few now, and this is the first step. The only difference is I dial indicate them after each 90 degree move and put it back at the spot with the least runout. I index both shafts if required, front and rear of each shaft. With the rear output, I mark the shaft on the outside, and the output shaft gets marked on the inside on the end. Most technicians will not take the time to do it right. Most want to order shafts and throw them in.
Sag2, You are obviously a craftsman with very high standards. Too bad there are not more like you. T
lets all go to the dealers in our area and test a few and let them know that the trucks will sit there until fixed :-laf
I have the same problem. I was told they all do this, have 9000 miles on mine and when I pull my bass boat I can not stand it because it worst. I can not stand to drive my truck between 65-70 over 70 or under 65 it's ok. I would love to do something about it.
