A lot of great feedback and I really appreciate it. This is much more than what I was getting from the dealer. Just to recap the diagnostics that has been done;
1. At highway speeds (50-70 mph) when the clutch is depressed vibration is reduced DRAMATICALLY however I can still feel some mind vibration. At lower speeds under 40 mph is hardly noticeable
2. Dealer installed a new set of stock rims & tires for road test only. Problem still there.
3. Rear DS UJ's (both) replaced.
4. Upper/Lower Ball Joints Replaced - They were bad but didn't resolve problem
5. Stock tires Balanced and rotated - No change in vibration
6. Check for vibration while parked, run engine RPM's from 800-2500 - Smooth no vibration
7. Dealer replaced last year front uj on one side and outer wheel bearing on other side. Can't find receipt, but work was performed.
8. No missing weights on drive shaft.
9. Dealer checked Front & Rear brakes and rotors checked good
10. Dealer checked front inner/outer wheel bearings checked good
