I just changed the motor and trans mts in my 92 4x4. they were really shot, now I have a little too much vibration at idle, I am thinking I need to get the injectors cleaned or replaced as it clears up under load and with some RPM. Anyone had the same problem ??? I also was wondering if the aftermarket mts are harder rubber that the stock ones and if that might be causing the problem... ??? I tried raising the idle a little made it better but it is still there...
