2nd Gen Non-Engine/Transmission vibration pbroblem
2nd Gen Non-Engine/Transmission changing the rear fluid
Engine/Transmission (1998.5 - 2002) 275 injectors and HO engine .
Got a vibration problem all of a sudden ,my legs will vibrate side to side at about 40 up. Thought it was tires so just got new Michelin ribs put on and I still have that vibration what would be suspect? Thanks RJ
Driveshaft loose, bent, out of balance, slip yoke worn, carrier bearing loose or shot, u-joints still good?
Could be your lock-up clutch in the tc. {been there done that]
If it is the old version @ your power good chance.
When mine went you thought you were going to loose a wheel!
