Virginia
Hawaii
New Mexico
I need a recommendation for a trustworthy independent mechanic in Winchester (I've moved to Clarke Co. ). My 03 is in need of new front axle u-joints. The dealer in Chantilly wants $600+. On my previous 03, I had to pay for the time that penetrating oil was soaking. I refuse to do that again since no labor was being done.
How different are the American axles from the Dana? I recently changed one of my front ujoints (on my '98). The hardest part was loosening the axle nuts. They'd been installed with a 3/4" impact wrench; there was no way I was going to get them loose. So I went to the shop that installed them and asked, "Hey! Can I pay you $20 to bust my nuts loose?" :) And, of course, the ujoints I bought were for the light-duty 2500; I had to go out again and buy the correct size.
I couldn't find a 6" bolt as Steve SL suggested, so I used the 4" bolt I found, put a short socket on the hex and a larger deep impact socket over the smaller socket, started the engine and used the power steering to press the hub off. Two good thumps holding the pressure for a moment did the trick; the hub nearly fell off. I forgot to use penetrating oil, but the P/S imparted enough force to bust the hub loose anyway.
While the hub was off, I dremeled the mating surfaces clean and applied an amount of anti-sieze to ease the job in the future.
Then it ended up being a matter of using small and large sockets to tap the old ujoint caps loose and using a vice to press the new caps/ujoint in place.
A 1-11/16" socket handled the axle nut nicely. I cheated when I put it back together. I tightened the nut to the requisite 172 ft-lb, then used the floor jack on the breaker bar to continue tightening the nut until I could get the cotter pin in place. (Actually, I could only find a 42mm socket; it was a snug fit, but did the job very nicely. )
It probably took me four hours to change the one ujoint. Twice. A cap fell off and I didn't get all the bearings back in place. So I removed it, tossed it in the trash and installed the second one. (One bearing was in the end and broke in at least several pieces. I decided to trash it rather than try to salvage it. $15 is cheap edjimication. )
So, the things you need to change 2nd-gen front axle ujoints are:
  • 1-11/16" or 42/43mm socket with breaker bar and an adapter if needed for the axle nut
  • correct ujoints
  • 12 pt. socket for the hub bolts
  • 6" grade 8 bolt same thread as the hub bolt to 'press' the hub off using the truck's P/S. A 4" bolt with nestled sockets to make up the 2" difference will also work
  • grease gun to lube the new ujoint and everything else while you're there
  • brake cleaner
  • work bench
  • bench vice
  • 3# mallet
  • a variety of medium and large sockets for general pressing
  • a nice sunny afternoon; not too warm, not too breezy
  • an extra pair of hands to hold stuff
Of course, you also need the tools to remove the brake caliper and a coat hanger to hang the caliper up out of the way. You'll need the mallet to tap the bearing caps out, and possibly to tap the axle out of the hub.
I would expect 3rd-gen axles to be reasonably similar.
Of course, if you have a life and can't find an afternoon to do the job, strongly suggest to the shop that they use the bolt and P/S trick to press the hub off; it'll save a lot of time and effort.
hey John, saw your truck up at the walmart in the dullus area. i parked beside you for a while. but left before you did. we aughta to another meet sometime soon.
Was in the Independence, Va area for the weekend and saw more Cummins Dodge trucks per vehicle there than almost any place I've ever been, it was right interesting. Never could get a good look for TDR badges, tho.
yea you wanna see a hand full of dodge cummins, go down round florida this time of year, or really anytime, and all them snowbirds with their campers head down. you go to a rest stop and there are dodge cummins everywhere, and some of those camper stops out in the national forest areas are just loaded with them.
I keep watching the site for something, and always look over the Chik parking lot, in case one of you is over there. I thought you would have posted a time for a meet before now. I am up for it.
well id think we should shoot for pretty much any friday night we want too. cause they got car shows up there every friday with good turnouts. and i usually with drive by on my way home from work to check things out. so if any of yall know youll be there, let us know.
hey guys just checkin in. got just got a black 4 door 3rd gen with a big cummins decal in the back. waitin for my tdr badge but im around hampton/newport news
I'm in the area also, you will find me at most of the Truck and Tractor pulls in Morgans Corner and ocasionally at the 1/8 mile track geeping the ricers at bay :-laf
saw a silver 3rd gen dually with stacks jacked way up passin the hooters in Hampton at about 8:00 on tuesday night. didnt see if it was a fellow tdr'r as I was in my buddies car #@$%!
I saw a silver 3rd gen in central park here in fred VA . it had tdr stickers and had some mods such as bumpers and exaust.
Hey SWithrow it was nice meeting you the other day. I'm thinkin of having a wrenching day hear soon at my place, i have a couple exhausts to do and some other stuff if anyone is interested.
Saw a blue 2nd gen heading east on W. Main St. in Salem this afternoon. As the neurons slowly fired, I figgered out who it was and honked. But the driver was engrossed in something else.
Was that you, Norm?
I don't see many at all, here in Winchester. Did see, however, a silver 2gen XCLB with bull-stax on it yesterday, in Winchester. .
