I was reading up the other night and came across a bulletin for 05 Jeep CRD's
Seems owners may complain of higher than normal temp readings especially in hot ambient, uphill or towing conditions.
Not a problem, just swing in to the Dealer and get your cluster re flashed with new software that will keep the needle at a more "customer preferred" setting.
So now this gets me to thinking and reading the Rams OEM manual. I find the Rams set up is the same as the Jeeps as far as how it arrives at the needle position but did get a partial relief reading this statement-
"The needle is moved to the actual relative temperature" of course this is based on the sensors input to the ECM and the clusters interpretation of the ECM's output to it based on its programming. Makes you wonder...
So does the statement in bold make it real, or does all this sound virtual?
