JD, thanks for posting the cool links...I didn't realize that the silicone fluid used in viscous dampers has an actaul lifespan based on hours used, or the mileage driven equivalent. However, IMHO 500k miles or 15k hours is still MUCH longer then the oem, elastomeric damper is going to last on a 5.9 ISB. It actually might even be 2 or 3 times longer, according to Chryslers' inspection criteria, for which (IIRC) it is recommended to inspect at 100k intervals for elastomeric deformities and other damper irregularities.
And while you are right that it MIGHT be misleading by Fluidampr to market their product as "lifetime", in their defense, unlike the Cummins ISB, most engines do not run even close to 500k between rebuilds, with gas engines it's much closer to 200k, if that, and in race engines even MUCH less, so for practical purposes, a Fluidamper lasts for several engine rebuils,( of course, like your other article points out, as long as you DON'T drop it during the rebuild, but that is NOT really Fluidampr's responsability, right??...lol). But also in thier defense, they sells their design for many engine applications OTHER then the Cummins ISB that CAN last 500k or MORE between rebuilds, so really it is probably more of an oversight for the FLuidampr ISB applciation, rather then being intentionally misleading on their part. And ALL that being said, even more items on your truck in general, as well as some parts on the Cummins, including the exhorbitantly overpriced common rail fuel injectors, will need to be replaced during those same 500k miles. And in fact, without adequate oem fuel filtration, the $2500 injectors will likely even need to be replaced TWICE during that same 500k miles.
Why am I saying all this??? Simply beacuse I think the Fluidampr is a solid upgrade to the oem elastomeric dampers on the 5.9 CTD. and worth what it costs. Though I DO know that one or two members here on TDR had a ticking noise that they did associate with their Fluidampr install. The ticking bothered them so much, (rightly so, by the way) that they removed the Fluidampr and installed the 6.7 ISB damper.
Personally, I am running the viscous damper from a 6.7 ISB on my 5.9 ISB. I did it that way just because, in general, I like to upgrade my 5.9 CTD with 6.7 parts whenevr plausible and cost effective, but also, becuase the 6.7 damper is actually even heavier then the Fluidampr. ALSO if you also change the fan pulley, you can still slip in a serpentine belt replacement WITHOUT removing the damper bolts, which is DEFINITELY a plus for me in the event of unforeseen roadside repairs. And in fact I HAVE had the serpentine belt FUBAR on the road, though luckily the road was still on my property, and dam close to my garage!!!
Sorry for the long wind...just my .02....again, THANKS for posting the links...the MOST important parts of which should be to encourage poeplt to actually INSPECT the dampers on their truck as routine maintenance at higher miles driven.
