i recently purchased a new vp 44 injection pump from ebay i put the new pump on and it has worked fine for the last few weeks . i put a psi gage on the pump to check fuel psi from lift pump i got the following readings 10 psi idle,lite acceleration 8 psi, 10 psi 1500 rpms, wot 4 psi, 3200 rpm 6 psi, I have tried contacting the "d-m-fr" that sold me the pump about a hundred times with no avail so hopefully somone could tell me if these psi readings are ok also was wondering what would make pump go out in the first place?
