The dealer just changed my pumps out and now I have the in-tank pump,
My idea is to put a 8 psi carter where the original lift pump was located. Now my question is: The new in-tank pump uses the stock pigtail plug to fire a relay to power that pump. Can I splice into those 2 wires to run my 8 psi pump? If so, does it matter which wire is hooked up to either post on the new 8 psi pump?
No other pump brand recomendations please.
Thanks Phil
Thanks Phil
