It will run, but the performance might not be the same. If I remember correctly, the HO pump has smaller flow internals, but different software on the internal controller. The SO pump has higher flow internals, but again a less tuned internal controller.
The pumps will work on either truck, but you might have a slightly lower performance with the SO pump. Functionally, it should work fine (assuming that there is nothing wrong with the replacement pump).
