Originally posted by jmadden
here's the feedback I got from Cummins following my VP & LP failures...
"On ISB engines, the lift pump does not start operating with the key switch on until the engine is bump cranked.
Then it starts working for 30 seconds and then shuts down by itself. During 30 seconds of running, it primes the
fuel system. Pressure during this running period should be around 13 to 15psi and during cranking, the pressure
should not drop down more than 8psi. We have seen in the past that even if the pressure are found to be within
specs, priming pumps due to internal check valve and excessively worn out pump impellers, that it creates fuel
spikes which create and pump air into the fuel system, which leads to the major problem in the VP44. There is
no fool proof methods to check the internal condition of the priming pump or to check air created by the priming
pump. "
So what do you all think about that?
jm
I think they just said that FP gauges don't help save the VP-44 but it can tell you if your LP is dead. Also sounds like the air in the line is what hurts the VP44 the most. Sounds like your most valuable part of the CTD is the 100K miles warranty. Go figure
