Not being scientific or anything,, But I was thinking (Watchout).
We have gauges for EGT, Boost and F. P.
Here's my thought(s)
The VP44 is cooled and lubricated by Diesel fuel.
A healthy original Carter fuel pump pushes 15PSI. I don't remember the GPH but thought it was around 60GPH.
If the '44 returns 60-70% of th fuel back to the tank,, that fuel had to be used to cool the injection pump. If it is used to cool the pump, That means It MUST have gotten warmer, and by monitering the temperature it may be possible to determine the workload and temperature of the VP44.
The gauge should be able to read from about 30-60*F all the way to 200*F. Since the VP44 is right next to the motor and right behind the radiator, and is also working to pump fuel at ~20,00PSI it has to be hot. Especially with the 100*F days that Will soon be here in South Texas.
Would it be possible to put something like a Transmission temperature sender in the return line of the VP44 and moniter the temps? Would this be necessary?
Is the solenoid that controls how much fuel is delivered also cooled by Diesel fuel? If so then you could now when you are pushing the VP44 to it's limits.
This is my personal opinion here, experiance, and thoughts:
My truck is BOMBed,, My Mods rumour me to be at 375RWHP. I tow a 20,000 Pound gooseneck,, and I have BOMBed my transmission (6-speed) Clutch (SBC 13" clutch) Fuel Pump (Dual Fuel Pumps from ADT) and Brakes (Full severe service kit from EGR) to tow this weight.
Right now with my COMP on 3x4 I can be WOT for minutes at a time keeping EGT at ~1450*F max. Now I moniter Fuel Pressure, and EGT,, But what about my VP44?? I don't think it's as cool as a cucumber pumping all that extra fuel Especaillay when the water temerature is at or slightly over 190*F.
Will monitering the VP44 return fuel temperatures give any warning of an overheating, overstressed, or overworked injection Pump?
Anyideas would be appreciated.
Merrick Cummings Jr
Merrick Cummings Jr
