The truck has developed a knock that is noticable on decelleration from 1600 rpm to idle. The HRvp44 is new and the knock started shortly after install, the truck has 210,000 km making it possible for the bearings to be shot. I thought at first it was injector knock so I changed them out with a new set on jammer 3's and adjusted the valves and there was no change. You can't here any knocking under power or at idle but there is an occaisional miss at idle.
I'm think I will pull the hrvp44 and send it in for testing, I guess if it not the pump it's engine pulling time.
Any ideas would be helpfull.
Thanks Bret.
Thanks Bret.
