Hello,
I have a 2002 dodge ram with a HO 6 speed. I have a EDGE comp box and i just sent it in for a up grade to 8. 0 software. I am still having a problem it is when the box is on any setting if i get on gas and let off quick the truck will act like it has a bad miss and i will sometime die and i will have to use starting fluid to get it running again but this does not happen all the time i do have a fuel gauge and it never goes dead when the truck acts like this. i have 17psi at idle and 12 at full speed. i also have a set of 275 rv injectors. one last question is that it will idle up to 850 to 900 rpm when the clutch is in and once i drop to 5 mph or dead stop it will drop idle back to normal. any help would be helpful. i leave in denver colorado.
