I have just completed a FP/Boost/EGT gauge installation. All of it was done in anticipation of the removal and replacement of the VP44 fuel injector pump replacement. My first pump failed at 79,000 miles and was covered under warranty. The second is now at 158,000 miles. It has followed a common failure mode--lift pump failure followed by the injector pump being destroyed.
I am following Bob Wagner's posting on the replacement of the VP44 and I have found his suggested procedures to be detailed and accurate for a 1998. 5 2500. I am stopped at step 27 under removal since the support bracket was indeed broken. I hope Dodge has engineered a better solution for this part since it appears that the bracket was repaired via welding at the earlier replacement.
Some others have suggest that align the key in the 12 o'clock position with a breaker bar on the altenator pully nut. I was surprised that it turned so easily.
So far, so good. Let's hope that the part comes from DC tomorrow.
