I think maybe I finally see the light on one piece of the VP44 puzzle, as to flow rates...
I have been looking at the VP44 as though it had 2 relatively independent flow paths - one, thru the injector pump portion directly supplying the injectors, and at a fixed rate due to pump piston/bore size per RPM - and the other that FEEDS that portion, but bypasses excess fuel thru the VP44 for cooling and elimination of unused fuel - the kicker being, I have been looking at that bypass as an *open path*, that could, to a degree be varied in flow rate by varying inlet pressure to the VP44 as any other open but fixed orifice would be.
BUT, I now realize (I think), that the bypass section is ALSO flow restricted and controlled by a FIXED condition created by the VP44's internal lift pump that supplies/controls 100% of the VP44 internal fuel flow. Put another way, I *assume* that if the VP44 is NOT physically rotating, NO, or precious little, fuel will flow thru the VP44 regardless of applied pressure - and what DOES flow during normal operation is STRICTLY controlled by the RPM of the pump, only so much volume of fuel per RPM can get past the rotors/vanes of the internal lift pump - regardless of whether there is 1 psi or 100 psi available at the pump inlet!
I understand that there IS a SMALL vent orifice AFTER the built-in lift pump incidental to the bypass pop-off valve designed to vent air in the fuel if need be - but apparently, that is AFTER the vanes or rotors of the pump, and other than (maybe) minor leakage past the pump rotors, not much incidental fuel can get past?
To summerize:
IF I am correct in my evaluation, then, ALL fuel flow thru the VP44 must FIRST get past the rotors/vanes of the built-in lift pump, which is strictly controlled by RPM - NOT pressure of fuel at the VP44 inlet. THAT being the case, in terms of volume, it really doesn't make any difference whether there is . 1 psi or 100 psi at the inlet - only SO MUCH fuel can physically pass thru the pump per revolution - and as I understand it, based upon the maximum operational design RPM of our Cummins, that amounts to about 45 GPH maximum - regardless of fuel pressure or the size of fuel lines and fittings.
OK - beat me up on this and tell me where I went wrong...
(other than not comprehending that in the first place... )
To summerize:
