Here's the skinny........
I believe the filter rating was 10 microns at 45 GPH. So far it has held up longer than others I tried and no loss of pressure.
Here's the part #s all available fron Napa.
Fuel Filter #4006 $7
Filter Mount #4309 $27
Pusher Pump #P4070 $90 (Napa packaged Carter 4070 pump)
Don't forget to tell them you have AAA or some other way of getting a discount.
Because of the size of the filter mount and where I originally mounted the pusher I didn't have much room for fittings. I wanted to put some valves on to accomodate changing the filter but there was no way without moving the pusher way up. I do have some vice grips with the flat ends that gently squeeze the hoses shut and that seems to work OK. It's working for now so I wont mess with it.
Garrett
Garrett
