smokingoat01 said:For all those interested, I just put a p pump on my 01' 5 speed this last week. I ground a number 10 cam plate and slid it all the way forward as well as sliding the AFC housing all the way forward. I'm am extremely satisfied with the result, I pulled my 32 foot tandem flatbed trailer hauling a 4640 John Deere and it had no problems. As for exhaust temperature it does stay in the range very well until you pull say a 7% grade then you have to back out of it just a little but otherwise its not an issue. And I do have the factory turbo on it with only 4 inch straight piped exhauast. As far as parts go, I bought a complete 12 valve core motor for $500, and the injector lines and the cam shaft (to run the mechanical lift pump) from haisley machine for $850. You will also need an adapter that screws into the side of the pump in order to get the oil supply to the pump from the block. I think it was $15 from Scheid. I already had DD2 injectors in the pickup. Everyone tells me the engine will run much smoother with bigger injectors when you do this swap, and it does. I also put a 4000 rpm governor spring kit in the p pump. A word of caution on doing this is not to rev the motor past 3500 rpms unless you have heavy duty valve springs as you will have valve/piston contact. This applies to 12 and 24 valve engines. As for the tachometer, the 01. 5' pickups and later have the cam position sensor located on the timing case behind the injector pump. Earlier 24 valves have it around the starter on the flywheel, I think. I know the tach is not an issue on those trucks. This was the only hitch I ran into; however I have access to a CNC mill and so an adapter was made to keep the cam sensor in place on the 12 valve timing case that was used because the pump mount for the p pump is different from the vp-44. I will sell these to anyone interested as the pattern was saved. I used the 24 valve throttle mount (AP sensor I believe its called) with some modification and was able to retain the cruise control. I set the timing at 18 degrees as the concensus from local mechanics was that this would be the best for all around performance. So for all the detractors who are against doing this and say it is impossible to do, or would cost more than the truck, or will not be streetable, think again. Anyone with questions feel free to ask because I've got a pickup that turned out great with this swap. I live in Central Texas so anyone who would like to see it or drive it feel free to ask.
Silver Bullet Ram said:Will this work with an auto trans? Someone at Scheid said it would be difficult because of something to do with a tps. Is it still pricey to do this conversion? Last I heard and it has been awhile was like 8k.
EMD-Run8 said:I'd be curious to know how you could drive the tach and other instruments on say..... an '02 6 spd truck?
massdiesel said:You have to machine a hole in the timing cover for a cam sensor and the tach and cruise will work and also for charging system
A LOT of work. It's all been said before. Do a search.
I guess that really depends on what one considers "a lot" I would rather do this swap than than R/R/R the transmission/transcase.
And I do not think it has all been said before, I have searched, not just here but every diesel forum and it has been talked about yes but not much detail.
I found the info I was looking for in the F/S manual and Cummins Quickserve.
The one thing I have NEVER found anywhere is anyone that has actually done the swap wishing they had their vp44 back. One can put a "box" on their vp and get more power but you can not make it more reliable. Remember even the guys who say the "NEW" vps are so much better STILL have a backup pump onder the seat or in the shop
Is this for everyone, I would say NO. Will it effect resale? It MIGHT, depends on who your selling to, might make the truck MORE valuable to someone who knows what they are looking at. And to me it matters not cause I do not plan on selling anyway. I am just building the truck I wanted to buy 7 years ago.
After doing this and now KNOWING what is envolved, it for sure will not be the last time and the next one will most likely be on a CR block
