Installed vulcan big line kit and moved to rail just in front of tank. Tucked above the transfer case skid plate.
Also just replaced lift pump . The other one was having intermittent psi issues. It would be running at 12 psi while cruising and then drop off to 7 psi and stay there untill I gave it some throttle and then it would go back to 12 psi . Then when back to cruising it would drop again.
It also would only go to 5 psi when bummping the starter. Pump was only 8 months old , local part store replaced it under warrenty.
Vulcan kit was a nice easy install and even with the old pump when it was running at only 7 psi when I was wot it only would go down to 6 with the big line kit
I will udate new pressures with new pump when I take it for a run.
Attached pictures of completed install
