VW bug fuel line insulation
48 year old engine still has teeth!
2018 Ford 150 LTD tailight R&R costs $5000 ??
Bluebird
`72 Super Beetle copper fuel from firewall over intake manifold. What's the best material to insulate this fuel line? It will touch the intake manifold. A split rubber hose or a fabric braided rubber hose, or another insulated material? Thank you all who share mechanical wisdom. Patrick
"Scotch 27 Glass Cloth Electrical Tape" might work. It operates at Class B 130°C (266°F). It has thermosetting pressure-sensitive adhesive. I used it to fix a commercial 240VAC electric table-top fryer. When I opened it, the wires and connections were so bad I was surprised it hadn't gone up in flames already.
Made for wiring, but might just work well on a copper fuel line.
Here's another option, https://www.mishimoto.com/heat-defense-reflective-tape-15.html
Vapor lock can be a big problem with fuel lines that run close to a high heat source. Many a small engine had a steel fuel line running next to head and after running for awhile in overly hot weather, would buck and miss then shut down! What pain and not good for a vehicle at all! Sounds like a fun project. Back in the day, had several VW dune buggy type rigs. Was great to be able to swap out a motor with a few nut and bolts, throttle cable and a couple electrical connectors! The fun and crazy times of our youth! :rolleyes:
Should a fuel line, Copper, that comes from the Firewall really touch an engine intake that moves around quite a bit? Doesn't sound like German engineering to me.
A picture of the situation would shed some light here.
