I have a syou can see below a 98. 5 24V. I have had a va box, BD exhaust, 4" exhaust system, and 275's for about 2yrs. The only problem I had till recently was from the stock clutch at 92K mi. I had just switched from the VA box to a EZ Comp. WOW! it really goes but so did the clutch. South Bend fixed that but now at wot on a setting of 3 or higher at about 2300RPM's I get a stumble, feels like no fuel. At lower rpms no problem. I dont use 3-5 on the box very often usually just to have fun. My lift pump is original now with 112,000mi. i does work as I can hear it run and shut down after a bit. Two questions, i beleive its the pump and i can get one from Cummins in Reno but should I do that or replace it with something else? Is there a dif. between the pump Cummins has and the Dodge dealer? and where is the best place to buy a gauge? Going to do that as well , help form you pump gurus would be appreciated! Thanks Dave
