RSchwarzli
BWAAAA HA HA HA, the early pic of the frame going down the driveway... . looks like it was trying to get away, like a puppy from a bath!!!:-lafI love it!! Great job on the whole shebang. I'm sure glad to see more than a hubcab coming out to the hub... . Did they carry two spares?
Yeah. LOL. No spares when I got the truck!
LOL. I do love that shot too! :-laf
Also, do you have many miles on the Gear Vendor? I've had hell with mine, it doesn't do well with pulling a trailer, it seems. I try to change the oil every 10,000, and it drains glitter out every time... .The first one was in it when I got it, and it lasted about 25K before it completely quit, and this one only has around 20k on it, and the last 5-6 times I've changed the oil, it's not been pretty.....
My gear vendors that is in th 1990 has about 30K on it. It also has glitter in the oil. Seems to be holding though.
Do you use the e brake with the GV on?
OK on the Frame , Im trying to reframe from welding in a mount for the Clutch Master cylender . I thought about a 94 to 99 or so master cylender since they bolt on , the later ones are adjustible . But no one has yet to answer my question ( parts houses included ) that can tell me the lenghth of the push rods of a 93 unit and the later units .
If there was both on the shelf it would be easy to tell does any one have this answer or work some place that can look and measure it ?????? I called South bend , no help there either but said " measure it then we can fix you up " Thats no help you cant measure it in the truck !!!!!!!!!!!!!!
What rod are you talking? The slave the throw out bearing or the one to the brake pedal?
As for the 93 master that connects to the pedal, mine just fits in. No messin around. Does yours not?
What ever happened to the old style manual over under drive aux. boxes you used beable to buy they never had any issues ? Plus the second stick in the truck was fun !!!
I will be running three shifters!
One for 6 speed, one for high/low range. One for 4wd. I have them connected all on their own now!
