Well, it has been a long time since I did an update on this. Now is March 2017….last update seems to be 10 months ago… sorry. (EDIT: Actually, it took me a month and a bit to actually finish writing this and it is now May….sorry guys and gals) Truth be told, I didn’t touch the truck much during the summer last year but although I have been quiet so far on the forums this winter, I have been cooking with bacon on the truck with my goal of having it at a few shows this summer (2017)!
I have been trying to spend more time working on the truck and less time farting around online as it is time to get this sexy beast done and we all know how fast we can use up playing online…. So I haven’t updated much. But that means there is lots to update now. So I will try to pick up where I left off….
I left off with the interior wiring beginning and some exterior work being done. Both have continued. As we left off with the interior, let’s start there.
THE OVERHEAD CONSOLE
So I started on the overhead console. It is time to get this done as it is time to get on the interior wiring and headliner. So I started with the actual sheet that will become the rigid sheet that will support the rockers. So I started with some 18 ga sheet metal (if memory serves).
Drew my templates as to how I wanted to group the rockers. I did them by function. Ie, all lighting rockers together. All pneumatics related. Etc.
So the panel was cut out and filed so the rocker housings had an exact fit and didn’t rattle around.
Then came the test fit.
Then came the fun part: mounting this into the overhead console. Issue is, you can’t use screws, glue won’t hold long term, so you have to be creative. This is how it will look.
But for the backside, that’s where you have to get a bit creative. As the console is bowed, and the switch panel can’t be, I had to create a small bridge to block the hole. This was welded to the panel.
But now we have to hold it in. So I determined it will need to be an exact fit press in design. The theory will be to block it in via wood, so it holds tight but can be removed if needed. It will also give me a good solid rigid backing against flex.
Slowly getting the shape in…
And now to plane the wood to make it exact fit…
And then at 4 hours and a lot of trial and error, and it all fits.
