walker mufflers
Brake fluid change, per J. Anderson
does anyone know napa's part number for the walker muffler???? I went to the local napa store today and they said the only muffler they showed for our trucks is $130 thats a far cry from the $46 walker muffler I was reading about in prior postings. Thanks in advance you guys are a great help!!!!!
Originally posted by sanger:
Firefighter hope this helps Napa has a huge catolog on line at http://www.napaonline.com
Stephen's 1995 Dodge Cumming Automatic 3500 in Sanger CA. Pulling 35 Foot 9600 lbs 5th wheel. BD fuel plate 230HP,Air Filter Boot Removed, Gutted Cat, Vibrating Mirrors, Sreaming Tubro
Just order a straight pipe and install it for much cheaper. You'll hardly notice the difference. The turbocharger is an EPA-DOT certified muffling device.
Chris Timochko
1997 5sp 4X4, HX40, BD 4" Brake, Marine Compression, Custom Tuned Injection Pump, 370B Injection Nozzles, Delivery Valves, Governor & AFC Spring Kit, Psychotty Air, Water Injection, NOS Diesel Kit, 6" Chrome Exhaust System, No Smoke Valet Switch, McLeod Dual Disc Clutch, Mag-Hytec Rear Cover, Cummins Chrome Kit, Optima Red Tops, Hadley Bully Horns, Hurst Line Loc, Goodyear Wrangler AT/S 305/70/16s. Test mule for Auto Wurks Diesel race program
I have the Walker 21468 on my truck. I scavenged the muffler from a friend who went to full 4" so I didn't pay for it. I think he gave something like $70 for it though. Sounds good on my truck, I have too many valves now but its a little more mellow than my 96 was with a straight pipe. Sounds real cool in tunnels and next to walls.
2001. 5 2500 4X4 SLT, ETH/DEE, Amsoil Bypass Filtration, Mag-Hytec w/Amsoil, Walker 21468, 6K@110200
The NAPA part number for Walker mufflers is exactly the same as Walker's. I recently bought a Walker 21471 from NAPA, cost me $115 including tax with my commercial discount. I think they said the regular price was $130 plus tax.
Firedude,
Here are some specs to chomp on from J. D. previous investigation:
Walker#
21468 6x22. 5 case, 29. 5" long, 3" in/out
21471 7x28. 5 case, 35. 5" long, 4" in/out
22572 9x20. 5 case, 27. 5" long, 4" in/out
On my 98, I put the 22572. The body diameter is just a bit to big for a perfect fit, and will contact frame components with a gutted cat in place too. You can fab it in anywhere in line if you remove the cat altogether. If you want to keep the cat and put the muffler on behind and want the 21468, you can use an adapter to go from the cat 4" to muffler 3" using Walker# 41563 reducer.
Hope this helps,
Steve.
98 qc, 12V, 4x4, slt laramie, 3:54 ls diff, 2YG pkg, Kelsey trailer brake control, dodge running boards, diamond plate bed rails, prime designs bug shields, silencer ring wind chime on porch, Raven cab-hi camper shell, psychotty air system, T/C lock-up switch, gutted cat, Walker muffler 22572, crome 5" tip from Kenworth stack, Isspro guages, A pillar 3 guage mount, TST #6 250/635.
Toys: 70' F250 4x4 highboy- 429cid 400+ hp on 35"BFG's(ranch truck) 64' MF 205 tractor 3cyl perkins diesel w/bucket
I talked to Walker yesterday - the 21471(straight thru,no open cavity in the center) is the best flowing of all their mufflers. They have a new glasspack(16"x6")4" straight thru. I got the 21471 wholesale for $70. 52. I think I'll try it straight for a spin around the block before I put the muffler on! Craig
