IS it "paranoid" to take steps to avoid a well known weakness, or premature failure? Perhaps - but I take the SAME steps in carrying a SPARE TIRE in my truck! The relatively high failure rate of lift pumps is now well known and documented - AND also relatively easy and inexpensive to delay or absolutely AVOID! These pumps (or ANY of the other replacement types!), even when of excellent quality, and without complicating factors such as dirty fuel and poor installed location, WILL eventually fail and need replacement - the BEST we can hope for, is to DELAY that event as long as possible, and MONITOR system operation as to be aware when that time comes - the same as we monitor coolent temperature and oil pressure!
"Paranoid?" - OK, if you insist - but it's now one less thing I need give much more than an occasional glance - even WAY out in the boondocks...
"Disadvantage of having two pumps in my thinking is that if one of them fails (for what-ever reason) then that would produce a possible OBSTRUCTION..... and that would bring us right back to where we started from. "
Perhaps - UNLESS you do THIS:
And installed:
You will note the bypass AROUND the added pusher pump, that slightly reduces total system PSI down to a reasonable level - 21 PSI or so at idle, 20 at cruise, 16 at WOT up a grade towing our 5er, and Comp on 5x5... IF that pump should shut down or fail, the included bypass valve opens under suction, allowing nearly full fuel flow AROUND the added pusher:
This scheme has resulted in less strain on the pusher, since it's working against less head pressure - and the same for the stock LP, since it no longer has to work so hard pulling the fuel all on its own - and NO intervention is required IF the added pusher fails - the included valve functions all on its own... AND, since MANY stock LP's apparently still allow sufficient fuel flow after failing that their owners aren't even aware of their failure, I'm pretty comfortable that if my stock LP fails, the pusher - along with the mechanical LP built in to the VP-44 itself, will still keep me moving... But of course, there's ALSO the SPARE LP I carry back in my toolbox...
"Paranoid?" - ME?...
NAHHhhhh - just cautious and PREPARED!
