SSolderitch
I still have the abs & brake lights on. (I have a rear wheel abs only) I was told the rear wheel sensor... . I replaced it with a new mopar sensor. Lights still were on/off/on/off... . So I pulled the ABS plug and with a meter got 1735 ohms on the pins for the sensor (1700 ohms with just the old sensor), 40A PDC fuse ok on 2 pins, 10a run fuse ok & grounds all ok. I didn't check the wire that goes to the pcm (yet) Have bought a used abs controller to swap out, not done. Anything else I need to know or look for?
