First, Welcome to the TDR! (well, the website at least heh)
Sounds like you have a sticky fuel shutoff solenoid. Locate the solenoid behind the inj. pump, it has 3 large gauge wires coming out of it vertically. Remove the retaining clip and pin that hold the plunger end onto the fuel shutoff lever for the inj pump. You`ll want to check the condition of the dirt boot on the outside of the solenoid before continuing. If its intact, carefully roll the boot off the lip on the solenoid, and the plunger should slide out to you. Check the inside of the bore and the plunger itself, and clean with a damp clean rag. Lightly oil it with non-detergent oil, and reinstall. .
Could also be some of the linkage in the area holding the lever up...
good luck
-j
