warped hub and rotor
Part Numbers Needed
To Install 3k Gov Springs
I just had my brake's done and the mechanic showed me that my front hub wobbles without the rotor attached. he installed the rotor 3 different rotation's and each time the rotor wobbled in the same place each time, so he turned the new rotor to take the wobble out ... do i need a new hub or can it be machined straight?
I would have replaced the hub before I let someone turn a new rotor to a warp. I think the warp in the rotor will show up again soon. Probably cheaper to replace the hub than to machine it straight.
I would have but...
the cost of the new rotor was 90 buck's and with a truck full of tool and no down time (hub not available ) I had to do it ! I'm sure the worble will be back soon but do you think I can have the hub machined?
