It would only effect the warranty that the turbo directly affected... for example if you blew a head gasket because your boost was 50+ psi then warranty wouldn't cover that. If you had the turbo on and your fuel pump or steering box goes out then warranty should cover that because that's not something the turbo effected. They have to prove that the turbo made or causes the failure to void or deny warranty...
