I have noticed the last couple of weeks that off the line power has dropped. I had clicked the AFC wheel about 20 clicks about 3 weeks ago and it seemed to have made a great improvement over stock. Now this started to happen. I was wondering if the Waste Gate is having problems. I checked the hose from the AFC fitting to the waste gate and it seems to be fine and no leaks that I could find.
It seems slower on start off and to get the power to come in you have to be in the upper rpms not in the mid rpms like it use to. Even in 4th it doesn't grab it and run like it use to. There is no miss's or bad idle.
I have a good coat of dirt on the K&N filter(PSA) and I was wondering if with the filter dirty that its just starving for air. I am going to clean it this weekend and see if that makes a difference.
Should I be able to move the rod that goes to the turbo when the engine is off. If you are suppose to, then there is a probem because this one is solid, I can't move it either way. .
Thanks
Rick
RICK
97 2500,CC,5 SPEED, 3. 54 Limited Slip,Psychotty System,K&N, Pre-Turbo ISSPRO 3" Pyrometer & Boost Guage,Silencer Ring Removed
12,000 RBW 5th Wheel Hitch,25' Excel 5th Wheel,Rancho RSX17000 Shocks,Amsoil Dealer,Straight Piped
Thanks
Rick
RICK
