I was on vacation this week so I got a bunch of stuff done to the truck that I had wanted to get done but didn't have the time. Adjusted valves, R & R prefilter, installed 215s, changed a leaking PS hose, changed gears in the front to match the 3. 55s in the rear.
Installing the 215s gave me a little more smoke but the boost didn't change any. My wastegate has never worked so I thought that maybe I was losing boost thru the actuator if the diaphragm was blown. Sure enough I can blow through it just using lung power. I have never developed more than 30 psi so I wasn't really worried about the wastegate working. I plugged the line and went for a spin and boost was up to about 34 and smoke diminished some. I realize I am still safe at 34psi but if I were to install a new wastegate actuator should I go with a stocker or is there a better aftermarket alternative? I guess I need to change that ticking lift pump next...
Danny
Danny
