wastegate - and boost pressure
oil filter wrench
275 Injectors & EZ Dyno results
2001 HO 6spd one month old, boost and pyro gauge, 4 inch exhaust is next. I read about using a turnbuckle to close the wastegate, can I do that on a completely stock motor or will I send the stock computer a wrong message and then have problems??
If you don't have a boost module you will set an over boost code in the computer.
Eric Pitts 2001 Properly Valved 2500 Qcab 4X4 auto Transgo shifts it 4. 10 LSD Weston Nerf Bars Smith built brush guard Command Remote Starter Scotty Air DD stage 1’s, PS boost module , elbow 32psi boost 247hp,657tq Neophyte B. O. M. B. er
The Pitts Home Page
Member GLTDR
Mike, your truck comes with a brass elbow that can be changed out for an adjustable elbow. Most boost modules come with a new elbow. The turnbuckle is for the hard lined wastegated Cummins. Pete
