Watch out Amsoil !!!
Spray-on Bedliners
EZ Power Edge install
Peter, from what I understand if you are running bio-diesel your oil will stay so clean that very little filtering will be necessary. The only contaminates will be wear metals and silicone, these levels should be low if your lube is working and air filter is filtering.
Peter;
Try the <a href=http://www.biodiesel.org/ target=_blank>Bio-Diesel</a> website.
Side thought: LPG and CNG fueled engines require a special extremely low ash and low phosphorous oil. I wonder if the same holds true for 100% bio-diesel? I'll have to make an inquiry.
-John
:rolleyes: Ah a question if you please. Has any one run this stuff in their rig for 50,000+ and towed 10k in 107deg F. heat?? What does oil analysis look like compared to synthetic or standard oil?? I'm not saying it good or bad, just looking for the posted results from real world users. :p :p
