RJPotts said:Have you tried draining the water from the fuel filter housing. That's where the sensor is and the water won't come out by draining the tank.
-R. J.
Are you catching what comes out and checking to see if there's H2O in it after it settles? If there's H2O then I'd keep purging the filter bowl every so often. If there's no H2O then I'd suspect the WIF sensor. MHO.ramman-mn said:yes i have drain the fuel filter 7 times
