It has been a long time since I have posted on the TDR. Well here is the situation.
I was on my way home from work when I noticed that I was not getting any heat in the cab. I looked down and everything was normal. I looked down about a minute or so later and It was getting close to red line so I pulled it over and popped the hood. Touched the radiator and it was cold. I shut the engien down. And got it towed home. It was about 2 and a half gallons low! Got under neith it and noticed oil had come out thru the over flow/breather on the drivers side. I check the oil dip stick and it was over full. I drained the oil and it was real thick. When the oil was almost done draining(like it was bearly dripping) when the water started to come out and it was not alot only like a pee stream. When it stopped i had about a gallon and a half of water come out. I took the head off had it check for cracks was cracked in 10 places. Got new gaskets, head bolts, the whole nine yards. Got it back together she ran great. Drove it to work no problems, on the way home lost heat again got it home and oil was coming out of the overflow/breather. I lost another 2 gallons of water. The oil this time is gray and thick. I pulled the oil cooler off this time and it is out to be checked for leaks. If it is not cracked I am going to put it back together ( hopping it is maybe a oil cooler gasket). If this does not work what else should I check??
I have been looking at the worst( Block being cracked). A local salvage yard has a 12v with 67,xxx on it and they want $1500 for it. It is complete engien.
Any help would be great.
Tony Stetson
(Sorry so long)
Tony Stetson
(Sorry so long)
