I have been allowing my pea-brain to get the best of me again. the latest thing to storm through it, is along the topic of water injection to lower EGT's under high boost conditions. for example 20PSI or higher boost levels or even a little higher 25PSI. mainly to use for those WOT bomb runs down the strip. or to allow me to stay in it a little longer on the highways
I have looked high and dry and found only a few squeeks of it around the web. mainly along the turbo-charged gasser lines.
anyone ever try this?
can any of you give me some numbers to shoot for, as far as pressure(bar) and ML's per minute needed.
I have found a few kits and think i could make up one just as easy, like i said, i just dont know where to start on nozzle sizes and pressures.
should i vary the rate of delivery in accordance to the boost level/s.
how fine of atomization do i need to be safe.
what kind of gains can i expect?
what are the down sides of it? any?
