Just get the belt off then unbolt the 2 10mm bolts (they torque @ 18ft lbs) then pull water pump out.
Install, just place new pump in and bolt up. Make sure that you have it right side up (make note of how the old one is mounted).
You might want to drain coolant from the radiator petcock so you dont gush when you pull the pump out.
