Picked up this 2018 3500 6 months ago to replace my 1st GEN that I had a long time.
So - question about water temp spread. After warmed up (30 mi drive) the engine water temp could be 165...180 ish.....and up to 204 deg. the 195 and above is normally while towing weather the outside temps are in the 40's or 90's.
I'm guessing that there is a 180 water thermostat installed and so water temps from 180-190 would be normal. and while at the 180-190 temps the guage is 1/4-1/3 scale. When the temps get to 204 the dash gauge is just below 1/2. The aux fan is not engaged yet at the max 204 deg.
What is the standard op temps and what is the max water temp? My old 93 only had the dash gauge and it was really rock solid at 1/4 scale unless the temp was upper end and the overdrive fan was on.
Am I just overthinking this topic because I can actually see the digital actual coolant temp?
thanks - rich
thanks - rich
