We have gauges.....take two!
Mobile Oil
96 P-7100 pump & turbo onto a 93
:D :D :D It is now official, I have gauges and they work as advertised. Install went OK, abut 6 hours. That drilling the manifold $**t sure is scary though!
Mopar guy filter on the way, better start looking for a 4" or an EZ, there's still room on the Visa... ... ... ... ... ... ... ... ... ... ... :eek: :eek:
BFC
What's normal #'s for a stock truck? I see 18/19 lbs of boost at WOT, transmission temp 180/190 empty and EGT's aound 900. Looks good to me, is it?
:D :D
Same #'s here. I see fuel pressures Peak low at 9PSI, but hold stable.
19. 5PSI max boost (That was running 100+MPH for awhile)
and 900-930*F EGT (Same run as above)
Here is a picture that I have thrown around a few times on the TDR. ( I am a little proud of the pic :eek: :D )
The truck was allready starting to defuel a bit.
Gauge numbers in pic. .
Fuel Pressure (Top Gauge): 'bout 9PSI
Boost (Middle gauge): about 18. 5-19PSI
EGT (lowest Gauge): nearly 900*F
MerrickNJr
P. S. Don't look to hard for the Speedo :D
If you can see the tach... I was in fifth gear.
I just installed mine to, my boost tops off at 16psi WOT and truck empty, 1100 WOT on the EGT. I have my stock plate slid all the way forword and the AFC housing all the way forword and the star wheel all the way in. No cat or muffler. :D Moparguy filter installed. Have no clue if that's good or bad.
And yes I know I need to call Piers and have him send me a STS cam plate amung other things. But... But... I just had to touch it!!! I can't leave anything alone:rolleyes: . IT'S ALL YOUR FAULT:D
Jim
Jim, I can simpithize, I put a #5 TST plate in my Ram and all I can say is " MORE, MUST HAVE MORE, " It's kind of funny though, It was fine until I became a member here. ;)
