JRMora said:It is much easier (and requires less fuel) to keep an object moving at a steady speed. The regenerative braking stores energy in the batteries that is used by the electric motor to accelerate the car. The batteries will die out after a short time depending on the load. A long uphill grade on a hybrid can get exciting (read slow) because the batteries die out and you are left with a 60hp engine to pull you up.
Diesels are the way to go - lots of torque to get things moving, high mpg's with you get to spped.
Juan
Electric are very efficient in stop and go. Gas or diesel are more efficient once up to speed. Electric gets it moving. Diesel keeps it moving. Electrics are very inefficient once up to speed. Too many amps. They can accelerate very fast from a dead stop though.
Ive read of a bus that uses an electric wheel to propell itself. Kinda like a train. It uses a rather small diesel to power a generator. This engine is at peak efficiency all the time. A diesel running at peak efficiency is very clean. Wouldnt even need egr. This bus got much better fuel economy than a normal bus.
