The engine codes are P0148 High Pressure Common Rail Checksum
and a P0514 Battery Temp Sensor Performance. Rail Pressure is 6700 psi at idle, IAT sensor voltage at idle . 8 - 1. 2. How do you check injector pressures. I did a injector test and all felt the same when shut off. On the 03-04 trucks the injectors sometimes crack somewhere with pressure boxes?? and how do you test for that.
