weatherfronts
more is less....
Clutch alignment tool
I ran a Dodge cold weather cover for 2 weeks and the zipper oscillated in the wind and put wear marks on the grill. It since has taken up residence in the garbage pail where it belongs. I like the grill honeycomb "plugs" but never seem to get around to ordering a set.
have had good response thus far this year. Thanks for all the good feedback and to all the orders!!:)
Still plenty left Follow the link above for the classified ad.
I purchased mine two winters ago from Eric and they are very cool to look at and install/removal is a snap.
You know Eric... . they are made too well... . once you buy them you don't need to fix or replace anything... you should find a way to cause them to break or crack to obtain repeat orders... kinda like DC's lift pump thing:rolleyes:
Thanks for the "quality" product:D
William
I think at 40 degrees below zero , your cold fronts that are mounted in the grill , are not helping unless you are traveling down the highway. . In severe cold wheather the only thing that will help you , is putting something directly on the radiator. . I have been useing cardboard for years , and it works great. . Just remember to cut the hole in the center to allow air flow. . Then it helps warm up at idle also. . :)
