NIsaacs
https://www.turbodieselregister.com/threads/deere-1023e-vs-kubota-bx1880.265434/page-7#post-2590991
Changed the transmission/hydraulic system today on the JD 4320 in preparation for a PTO/hydraulic powered wood chipper. Even thou the oil looked good on the dip stick, I have been wanting to change it since I bought it this spring. Not knowing when it was changed or what was in it....yup overdue. It appears to be the original, dirty brown with contamination swirls in it. When I pulled the suction screen, some pieces of drill metal were stuck in it. I would guess from when it was built. Then when I cleaned the return screen from the oil cooler (an inline) I found the line bent shut from someone running over a large object. Same with the hydraulic filter, a big ding in it.
