Competition Weight braket for a 2nd gen
Competition Manual beats an auto
Competition East Coast?
After this past weekend at a pull geting beat by 2 d-max's i came to the conclusion that i need a weight braket. what i need is some pics of diffrent ones and how to mount them. looking to hang 400-800lbs out front.
Thanks guys
The Fat Kid
Andy
With enough free beer I'm sure you could talk Jim and I into sitting on your front bumper while your pulling. Should be good for 550 pounds or so. Should be very easy to mount and dismount as well :-laf . I really need to get a clutch or transmission swap done so I can come play with you guys.
Bill
Do they allow hanging weights out front? If not, I have a weight box for under the bumper that holds up to 1,200lbs of lead bricks. Helps stiffen up the frame too. It came off my 98, so it will bolt right in, or I could take some pics of it if you want to fabricate your own.
1,200 lbs in lead bricks huh..... :) how big of a pain is it to install and or add weight? start taking pics and pm them to me i need some help on this one.
Chilly you nad jim might be 550 but not jim alone, you just need a clutch and a input thats all.
The Fat Kid
Andy
where did you get your lead, and price per lb if you don't mind. send some measurements with the pics, i am a welder for a living i think i can build it. :rolleyes:
The Fat Kid
Andy
Two angles that bolt to the Warn brackets. The weights hang on two pieces of flat stock that are 1/2" thick each.
The weights are 100 lbs. each.
I threw it together about 2 hours before the pull...
Justin
If you have tow hook brackets or not (the place where they go) you can weld a piece of 2. 5"x2. 5" reciever tube that you can pick up from your local Tractor Supply... . then just find some angle iron and some 2"x2" to make a bracket! ;)
