How would a weight Distributing Hitch work with a flat bed trailer when it is empty?
I have a 7000# GVW flat bed that I am considering using a weight distibuting hitch with in order to bring it back within the capacity range of the stock hitch. I understand that you set the tension on the bars with chains. Would there be enough adjustment to change from a loaded to an unloaded trailer? I have used them with Travel Trailers but their weight doesn't change as much as a flatbed.
Would an upgrade to a Class V hitch be a better way to spend the upgrade money?
Thanks for the help.
