OK, I just went out in the RV garage and pulled one of my factory 2001. 5 Aluminium wheels (you know, the ones with the Michelin 265x75x16's rated at 3415lbs Max single) out from under the back of the 5er and looked at it. It has a DC part number, however it does not include a weight rating. FYI the rear axle and springs are both rate at 6500lbs on my 2500 4x4 diesel. So if the truck came from the factory with 265x75x16, why does the door jam sticker say 6084lbs of the rear axle rating (2x times the 3042lb rating of the basic 245x75x16 tires) and not 6500lbs???? And why did they not up the GVWR to 9200 like the Chebby??? SNOKING
