is the recirc door and the bled door the same thing? i had my blend door done on my 06 allready. seems to work fine. but when a/c is on recirculate and you put fan on high it is louder blower motor sound than when it's on fresh air. . is this normal?
They are two different things. The recirc door is above the blower, and the blend door(s) are in the center of the HVAC housing. It is normal for the blower to get a bit louder when in the recirc mode than it is in fresh air mode. If it is loud all the time with low air flow, then the recirc door could be broken...
